June 6, 2014 at 12:15 am #198524
Dear Team, I have problems with the position-5 & position-7
When I use the position-5 to add a module, the module is doubled.
When I use the Position-7 is also duplicated in the position-5
Can you help?
Thanks-
Pankaj Sharma Moderator
June 6, 2014 at 4:06 am #537968Hello
Did you changed anything in php files ??
for example did you added new module positions in php files?June 6, 2014 at 1:02 pm #538064Thanks for responding! I do not remember doing anything.
I do remember that at some point intervene in tel template.css file to modify the logo measures.
Up there I can help.
Sorry for not being able to contribute more.
Hugs
SergioJune 11, 2014 at 12:52 am #538534<em>@sergiosp 431075 wrote:</em><blockquote>Thanks for responding! I do not remember doing anything.
Hugs
Sergio</blockquote>I have received no help or response for more than 4 days, could you help me with the problem?
sergioNinja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
June 11, 2014 at 3:00 am #538547Hi sergio,
I have enabled both position-5, position-7 positions in the Entrevistas menu, but I could not see the problem you mentioned, see the screenshot:
Please let me know how to re-produce this bug, I will help you out then.
June 11, 2014 at 12:54 pm #538603Dear Ninja Lead, the problem is inside, when you go to each of the items, can you check it? Please find attached a picture for you to see it.
Kind regards
sergio
Saguaros ModeratorSaguaros
June 17, 2014 at 2:39 am #539146Hi Sergio,
The problem comes from the template layout that you’re assigning to Entrevistas K2 category. With ‘ja_zite’ template layout, it will include ‘left’ column which also contains that position-7 position hence you saw that it’s duplicated.
I just changed it to ‘default’ template layout:http://prntscr.com/3tl4u6 and it works now.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 4 voices, and was last updated by Saguaros 10 years, 3 months ago.
