  • Mr.Cat Moderator
    #1066628
    @carlucci
    You can use this css
    .hits-summary { display:none }
    .product-desc {display:none }
    .product-item-actions { display:none }
    Remember to clear browser cache 🙂
    Wisdom is not a product of schooling but of the lifelong attempt to acquire it.
    carlucci Friend
    #1066777
    carlucci Friend
    #1066864
    carlucci Friend
    #1066866
    I solved the rest myself.
    .product-reviews-summary { display:none }   <---------------------------------
    http://pino.dietapino.com/index.php/es/filtro/filtro-de-recetas.html
This topic contains 4 replies, has 2 voices, and was last updated by  carlucci 7 years, 1 month ago.
The topic ‘[SOLVED]I need help css code.’ is closed to new replies.
