  • sergiosp Friend
    #932687
    Hello team! I have some problems with the operation of UBER Music on my site. The site is built almost entirely based on ACM and most of the menu in Special page: Blank Content. Except for the items; Blog (Articles »xLayout2) and Contact. When I get these two items (blog and contact), I can not these can be displayed with the same Header than other menu items.
    1) When I use the search engine, this brings me back to the page of incio unanswered about the search.
    2) when viewed in cellular, text placed in Intro Text within music-slide-items not seen. They can help me solve this? It may be easy to solve, but I can not give me accounts I’m failing
    Pankaj Sharma Moderator
    #933485
    On home page you are using acm-header module MOD ID : 554
    Open this module and assign it to All pages so you will get same view .
    In mobile the intro text hidden due to design concept . You can add below code in custom.css file to show it
    .acm-hero .hero-intro {
        display: block!important;
    Hope it helps.
    sergiosp Friend
    #933822
    Dear, I have done what you indicated me about acm-header module MOD ID: 554, but it was not. I still sending the page when I homer consultations in the search. You can give me a hand with this?
    What if it turned out was to add that little piece of code in custom.css, subtitles are now.
    sergio
    #933986
    I fixed it directly on your site , the acm-header position not assigned to default layout , so it was not showing .
    Check your site now : http://prntscr.com/b7pdih
    sergiosp Friend
    #934264
    Dear Pankaj, the search engine site does not lead me anywhere when I make a query.
    What could be the problem?
    #934303
    sergiosp Friend
    #935077
    Dear pankaj,
    I do not think he understood me. The problem is the use of Joomla search module. This instead of taking me to the results leads me to the homepage! Can you help me?
    Kind regards!
    Sergio
    #935195
    Please check the search module now .
    I set a menu item to show search result in module option : http://prntscr.com/b8x1ae
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 6 months ago.
