July 16, 2008 at 11:52 am #130927
hi
I tried to make so the JA TABS show some articles.In the JA TABS module i selected content and insert the this
{jatabs type=”articles” ids=”1, 2,3″ view=”introtext” position=”left” widthTabs=150 heightTabs=30 width=”600″ height=”230″ mousetype=”click” animType=”animFade” skipAnim=”false” duration=1000}{/jatabs}
in content code box. but i only get this http://serv1.mine.nu/viettan/
i found the code in the userguide
Nguyen Hong FriendNguyen Hong
- 20 times in 18 posts
July 17, 2008 at 8:49 am #260447Hi,
Please give me admin account access via pm , i will check for youJuly 25, 2008 at 2:03 pm #262297Hi
I dont want to hijack the thread, but I am having a similar problem with JATABS.
I have the Plugin and module published and using Joomla 1.54
CODE:
{jatabs type=”articles” ids=”14,15″ view=”introtext” position=”left” widthTabs=150 heightTabs=30 width=”600″ height=”230″ mousetype=”click” animType=”animFade” skipAnim=”false” duration=1000 }{/jatabs}Articles 14 and 15 is what I want displayed and are called Tab1_hd and Tab2_hd
Here is a link http://www.harley-ireland.com/index.php
dwernars Frienddwernars
- September 2006
- 4 times in 1 posts
July 25, 2008 at 5:59 pm #262325ids=”1, 2,3″
This part of the code needs to have the ID numbers of your OWN articles. – answer to bendikbygstad
esdigital, what I did was to create new custom modules based on the jtabs module, using the jtabs position and it worked just fine.
So go to your module manager, create custom modules called the name of your tabs. IN the content area of the new module – this is where I put the articles I wanted displayed.
I haven’t managed to get the plugin to work yet
July 29, 2008 at 2:38 am #262784Sorry for late reply, I have checked in your site, your jatabs plugin version is so old, you should remove current jatabs and download, install newest version. if still existing error, i will recheck for you.
Good luck ! 🙂1 user says Thank You to Nguyen Hong for this useful post
July 29, 2008 at 7:44 am #262852hi
this is what i suspect
thank you
Sherlock FriendSherlock
- 2478 times in 2162 posts
July 29, 2008 at 9:47 am #262874Hi bendikbygstad
Can i mark this topic is solved ?July 29, 2008 at 9:49 am #262875yes you can
This topic contains 8 replies, has 5 voices, and was last updated by bendikbygstad 16 years, 5 months ago.
