  • lgbtnation Friend
    #144016
    When I’m creating an article, I need for my readers to leave a comment. Is there a module for this now? I really need this or I’m going to have to change to drupal or wordpress. Help!
    Phill Moderator
    #316823
    There are loads of comment systems available. Google JED and select the one you want.
    I use jomcomment ( http://www.azrul.com/products/jom-comment.html ) as that fits my needs nicely.
    lgbtnation Friend
    #316825
    <em>@phill luckhurst 143888 wrote:</em><blockquote>There are loads of comment systems available. Google JED and select the one you want.
    I use jomcomment ( http://www.azrul.com/products/jom-comment.html ) as that fits my needs nicely.</blockquote>
    thank you!! I will check it out. Hopefully it’s not too expensive!
This topic contains 3 replies, has 2 voices, and was last updated by  lgbtnation 15 years, 4 months ago.
