tom_leif Friend
tom_leif
- October 2009
January 12, 2011 at 5:14 pm #158652I tried to look for the settings in the JAZ Plugin – and the complete site crashed. How can I get back the original teline III site look? Please help!
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
January 12, 2011 at 5:28 pm #371493Can you still access the back end? What exactly did you do in the JAZin settings?
asifak Friendasifak
- November 2010
- 2 times in 1 posts
January 12, 2011 at 5:29 pm #371495Did you looked at settings in the Pluin Manager in the back-end administration ???
tom_leif Friendtom_leif
- October 2009
January 12, 2011 at 5:34 pm #371496to be honest, I dont know … but the complete design of the site is crahed. I still have access to the backend. Do you know the basic settings of the jazin plugin?
- February 2014
January 12, 2011 at 5:42 pm #371498<blockquote>This plugin will find all available section and categories in your Joomla site and create all menu items link to such section/categories. Once created, menus item will be set to publish status. You can delete or unpublish unnecessary menus. The menu will be recreated if you choose “Update Setting” = Yes and click SAVE/APPLY. Go to http://www.joomlart.com/forums/showthread.php?p=49647 for more information </blockquote>
If you changed update settings to “Yes” and then hit save and apply all sorts of changes to your menu structure will have been made. Please read the aformentioned thread and if you cannot make heads nor tails of it come back with a link to your site.
I won’t ask if you backed up your database before fiddling.
- October 2009
January 12, 2011 at 5:43 pm #371499to be honest, i dont know, but do you know the basic setting of the plugin?
please have a look at the site, maybe you have an idea: http://www..citypets.dePhill ModeratorPhill
- February 2014
January 12, 2011 at 5:48 pm #371500tom_leif Friendtom_leif
- October 2009
January 12, 2011 at 7:25 pm #371520hi phil, thanks a lot for the pic and your help… i used the data, now i got a 404 error :-((
Laura Rubino FriendLaura Rubino
- 15 times in 14 posts
- October 2009
January 13, 2011 at 5:22 am #371596thanks a lot for help, i solved the problem!
- October 2009
January 13, 2011 at 5:23 am #371597Thanks, i solved the problem, site works!
- October 2009
January 14, 2011 at 2:08 pm #371865hi phill, thanks for your help a second time. when i saw the changes at my site i became extremely nervous, so that i was not able to solve the problem in a simple way. now i know, that my hoster makes a backup every day.
i am very happy that (even in the evening) here is someone who gives help immediately!have a nice time…
1 user says Thank You to tom_leif for this useful post
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 4 voices, and was last updated by tom_leif 13 years, 10 months ago.
I need urgent help!
