January 28, 2009 at 4:50 am #137585rhand Friend
rhand
- November 2006
- 15 times in 1 posts
January 28, 2009 at 8:41 am #288583I had a look. No idea yet I’m afraid. In IE7 and Firefox it is all good. Could be a IE6 box problem, but I haven’t figured it out yet. And the fact that I don’t have the pesky IE6 anymore (Thank God) and need to use IE rendering doesn’t help. Maybe someone else on the forum can help you out.
You could try a different doc type:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
instead of
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
But normally Joomlart templates are IE 6 proof and don’t require this change…
scotty Friendscotty
- March 2008
- 827 times in 595 posts
January 28, 2009 at 9:58 am #288594YOu need to add overfow: hidden; to #ja-sroll-1 OR add class=”clearfix” to the ja-scroll div.
January 28, 2009 at 4:37 pm #288675i tried changing the doc type in the index.php but didnt’ change
then tried adding this line to the template.css
overfow: hidden; to #ja-sroll-1 apparently didn’t change anythingOR add class=”clearfix” to the ja-scroll div. I don t know where this is?
rhand Friendrhand
- November 2006
January 28, 2009 at 5:39 pm #288683Sorry to hear it is not working yet. Try adding class=”clearfix to the ja-scroll div as Scotty suggested. The ja-scroll div you will find on the index.php of your theme.
January 28, 2009 at 5:59 pm #288688that’s where i thought it was.. but theres no ja-scoll in my index.php in the template files.. is it not in the joomla 1.5 version?
ewalind Friendewalind
- January 2009
February 10, 2009 at 10:06 pm #290522Did you find a solution for this?
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 4 voices, and was last updated by ewalind 15 years, 7 months ago.
IE 6.0 display problems
