graphicstylus Friend
graphicstylus
- April 2007
April 6, 2009 at 5:48 pm #139986Hello All,
In IE 7 and FF the layout is fine including the module and component. However in IE 6 there is major alignment problem. Would appreciate the help.
Site: http://www.epbhelpline.com/gs/
Problem: http://www.epbhelpline.com/gs/index.php?option=com_rstickets&Itemid=5If you see on any page including home the log in module on top is on the left instead of right in IE 6. You can see IE 7 and FF to see that the log in module should be on the right side.
Second on the above problem URL you can see that the component we are using is pushed far left with the logo and the left modules are under it. Please assist. If you dont see the problem, please let me know and I will provide screenshots.
Want it to look like FF and IE 7 on all browsers.
Thanks.
Css Magician FriendCss Magician
- October 2014
- 366 times in 263 posts
April 7, 2009 at 2:46 am #300357Hi graphicstylus,
In style.css line 374, change
#rst_wrapper #rst_content ul#rst_menu {
clear: both;
display: block;
font-weight: bold;
list-style : none;
margin-bottom: 30px;
margin-left:0;
padding:0 0 10px 11px;
position:relative;
top:1px;
width:98%;
1 user says Thank You to Css Magician for this useful post
graphicstylus Friendgraphicstylus
- April 2007
April 7, 2009 at 1:45 pm #300436Duchh – Thank You for the instant help! it worked like a charm.
The only thing that is remaining is the log in module. In IE 6, the log in module (yoo login) is still aligned left over the logo? I want it on the right hand side.
Any idea?
Thanks!
- October 2014
April 8, 2009 at 1:34 am #300481<em>@graphicstylus 123222 wrote:</em><blockquote>
Any idea?
Thanks!</blockquote>
Hi graphicstylus,
I think you should set width of #ja-topnav . Ex :
#ja-topnav {
width: 340px;
- April 2007
April 8, 2009 at 3:03 pm #300552Thanks duchh! You are a genious
This topic contains 5 replies, has 2 voices, and was last updated by graphicstylus 15 years, 8 months ago.
