  • Dean Howarth Friend
    #145191
    Hi I just launched my site only to finfd that a large number of corporate and government users are still on IE 6. And have mentioned that my site doesnt work. I am running JA Sullfur(Joomla) and JM Sulfur (Magento).
    The Magento side is fine but the issue is with JA SULFUR
    Appreciate any thoughts http://ocsgear.com
    Anonymous Moderator
    #320669
    Hi deanandeva
    I have checked your website and saw that you are install a lot of extensions.It is conflicting between extensions.
    you have to disable each module to find this issue.
    Dean Howarth Friend
    #320670
    The only module I have enabled are JA modules ?
    Is there anyway of testing a site for IE6 compatibility, other than installing IE6 ?
    Anonymous Moderator
    #320907
    Hi deanandeva
    If you only use our extensions with template, it will not have an error. But you are installing a lot of extensions. It is so hard to debug. You have to disable each extension to find what is the module which is conflicting.
    Dean Howarth Friend
    #320908
    Thanks will continue to dbeug from here
    didima Friend
    #320909
    l dont know why do you worry about ie6 this much, already died, and let others to worry. l dont like this ie6 do you know
This topic contains 6 replies, has 3 voices, and was last updated by  didima 15 years, 1 month ago.
