  • splifen Friend
    #141868
    I’am having problems viewing my homepage in Ie8
    http://www.bilcon.dk/
    Regards kenneth
    mfcphil Friend
    #307689
    Until you get a fix from JA Try to add the usual fix, go to your admin and find your index.php file
    add the following code into the first line of your <head> of that file
    <meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
    splifen Friend
    #307690
    I will try it tonight THX
    mfcphil Friend
    #307739
    Give me a shout if you get stuck
This topic contains 4 replies, has 2 voices, and was last updated by  mfcphil 15 years, 5 months ago.
