  • geof Friend
    #172750
    Hello ,
    I am having a problem with Teline IV when using IE 9.
    Firefox, Chrome are OK
    Could you please suggest any Fix?
    I am using Joomla 1.5.25.
    Thank you
    Best regards.
    hzc0mm Friend
    #433835
    Will be hard to tell without details or at least a screenshot, mate 😉
    I’m using Teline IV on Joomla 1.7, but had some troubles with IE9, too. Nevertheless I suspect you disabled CSS Optimization in the Template Manager. Set it to “minify & compress” for Teline IV, Clear JAT3 Cache & reload. Should work.
    If not, please post a screenshot and a detailed description of the error
This topic contains 2 replies, has 2 voices, and was last updated by  hzc0mm 12 years, 11 months ago.
