gringo211985 Friend
gringo211985
- May 2012
- 123 times in 27 posts
June 27, 2014 at 11:41 am #199205Hi there,
Just 2 small problems here,
When using Internet Explorer and I hover over a product it increases in size for some reason see screenshot below,
The product in red is the one that is being hovered over, as you can see it is bigger than the other products. How can I make it the same size when hovered over?
Next is the product image popups, see screenshot below,
how can I make them responsive?
Thanks,
Richard-
June 30, 2014 at 8:08 am #540591Hi Richard,
Which version of IE are you using? Did you experience the same issue with our demo site here? http://ja-bookshop.demo.joomlart.com/
For the image, the popup should be disabled in small screen as it will not look fine. I’ve reported this to development team for improvement on this.
gringo211985 Friendgringo211985
- May 2012
June 30, 2014 at 9:40 am #540606Hi Saguaros,
It’s IE 9 I believe and I tried fixing with the max height css class, but it’s still slightly wrong.
How can I disable the popup images on mobile?
Thanks,
RichardSaguaros ModeratorSaguaros
July 1, 2014 at 9:27 am #540771Hi Richard,
This is an issue of Mijoshop in mobile view. Could you please also post the same thread into Mijoshop forum? as I’m afraid that this requires some customization on this component.
- May 2012
July 1, 2014 at 1:38 pm #540800<em>@Saguaros 434695 wrote:</em><blockquote>Hi Richard,
This is an issue of Mijoshop in mobile view. Could you please also post the same thread into Mijoshop forum? as I’m afraid that this requires some customization on this component.</blockquote>
Hi Saguaros,
No worries, I’m struggling really bad with this whole Mijo stuff. I made a thread in requests and wishlists that highlight just a few of the very serious problems with Mijo including how they faked reviews.
Viewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by gringo211985 10 years, 6 months ago.
