  • frankiep Friend
    #145172
    Hi-
    I searched the thread for a solution but nothing seems to be working. I tried changing index.php to
    <style type=”text/css”>
    .clearfix {display: inline-block;}
    </style>
    .clearfix {display: block;}
    </style>
    it had no effect. looks great in ff.
    here is my url http://www.pretentiousplaid.com/jerrie
    any help woul be appreciated.
    Thanks!
    Fran
    instantinlaw Friend
    #320451
    This code in your index.php is incorrect.
    <link href="http://www.pretentiousplaid.com/jerrie/templates/ja_mesolite/css/ie8.css" rel="stylesheet" type="text/css" />
    Try removing what you put in the index.php and change the code above to this:
    < link rel='stylesheet' type='text/css' href='http://www.pretentiousplaid.com/jerrie/templates/ja_mesolite/css/ie8.css'/>
    But make sure there is an ie8.css file in the ja_mesolite/css folder.
    instantinlaw Friend
    #320453
    You can also force IE8 to render the page as IE7 if the page is displaying correctly in IE7.
    Just add this to the head of your index.php, right below the <head> tag.
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    frankiep Friend
    #320456
    Hi-
    Thanks for the advice. I tried both but I don’t notice any change. Anything else I might try? I’m pretty open.
    Best,
    Fran
    instantinlaw Friend
    #320457
    Replace your entire head section in your index.php with:
    <head>
    <jdoc:include type="head" />
    <?php JHTML::_('behavior.mootools'); ?>
    <link rel="stylesheet" href="<?php echo $tmpTools->baseurl(); ?>templates/system/css/system.css" type="text/css" />
    <link rel="stylesheet" href="<?php echo $tmpTools->baseurl(); ?>templates/system/css/general.css" type="text/css" />
    <link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/template.css" type="text/css" />
    <link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/typo.css" type="text/css" />
    <link rel="stylesheet" href="<?php echo $tmpTools->templateurl(); ?>/css/ja.vm.css" type="text/css" />
    <script language="javascript" type="text/javascript">
    var siteurl = '<?php echo $tmpTools->baseurl();?>';
    var tmplurl = '<?php echo $tmpTools->templateurl();?>';
    </script>
    <script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/js/ja.script.js"></script>
    <!-- js for dragdrop -->
    <!-- Menu head -->
    <?php $jamenu->genMenuHead(); ?>
    <link href="<?php echo $tmpTools->templateurl(); ?>/css/colors/<?php echo $tmpTools->getParam(JA_TOOL_COLOR); ?>.css" rel="stylesheet" type="text/css" />
    <style type="text/css">
    .clearfix {height: 1%;}
    img {border: none;}
    </style>
    </style>
    <?php if ($tmpTools->isIE6()) { ?>
    <link href="<?php echo $tmpTools->templateurl(); ?>/css/ie6.php" rel="stylesheet" type="text/css" />
    window.addEvent ('load', makeTransBG);
    function makeTransBG() {
    makeTransBg($$('img'));
    </script>
    <?php } ?>
    <link href="<?php echo $tmpTools->templateurl(); ?>/css/ie8.css" rel="stylesheet" type="text/css" />
    </head>
    frankiep Friend
    #320459
    Thanks instantinlaw-
    I tried it and it didn’t seem to change anything.
    Best,
    Fran
    instantinlaw Friend
    #320518
    Have you tried to submit a support ticket?
This topic contains 7 replies, has 2 voices, and was last updated by  instantinlaw 15 years, 2 months ago.
