  • hariorama Friend
    #158080
    hi
    in which file is this line?
    <!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd”>
    wibiya said to change to:
    <!DOCTYPE HTML PUBLIC “-//W3C//DTD HTML 4.01 Transitional//EN” “http://www.w3.org/TR/html4/loose.dtd” >
    in order to get the wibiya toolbar working with IE.
    and why is there always problem with internet explorer:
    Website
    other browsers are fine, just internet explorer, also version 8.
    hariorama Friend
    #369656
    changed template, now it works with same plugins, extensions, modules etc.
    must be a problem with teline iii v2
    thangnn1510 Friend
    #369791
    Dear Hariorama!
    I’ve checked and see the first line have been changed to:
    but the toolbar still not working, Could you give us the login information to your site via http://support.joomlart.com. We would check the problem for you.
    Best wishes and happy new year!
This topic contains 3 replies, has 2 voices, and was last updated by  thangnn1510 13 years, 10 months ago.
