  • steinm10 Friend
    #129516
    My site looks good for the most part, excluding the logo that i’m supposed to have placed in the top left corner of the site. I’m also using IE6 which I know is causing the issues, but I’m not quite sure how to fix them. Could somebody please help me ASAP!
    Also, their is an image on the bottom of the main content area that is not showing up properly.
    http://www.mbf-events.com/pga
    Menalto Friend
    #253609
    Please correct this errors first:
    Warning: require_once(/home/.pischi/steinm10/www.mbf-events.com/pga/plugins/content/../../components/com_rsform/controller/adapter.php) [function.require-once]: failed to open stream: No such file or directory in /home/.pischi/steinm10/www.mbf-events.com/pga/plugins/content/mosrsform.php on line 9
    Fatal error: require_once() [function.require]: Failed opening required ‘/home/.pischi/steinm10/www.mbf-events.com/pga/plugins/content/../../components/com_rsform/controller/adapter.php’ (include_path=’.:/usr/local/php5/lib/php:/usr/local/lib/php’) in /home/.pischi/steinm10/www.mbf-events.com/pga/plugins/content/mosrsform.php on line 9
    steinm10 Friend
    #254002
    Error has been updated.
This topic contains 3 replies, has 2 voices, and was last updated by  steinm10 16 years, 6 months ago.
