  • cdboutique Friend
    #151166
    Hi all
    RE IE6 COMPATIBILITY ISSUE WITH JA LEAD
    I have searched the forum for an answer and haven’t found one pertaining to my particular problem, so i thought Id post this thread.
    My website loads very VERY SLOWLY,slowly, sometimes taking 5 minutes to load, or sometimes not at all when using IE6, depending on what computer I’m using, is this a common problem,……is it a quick fix? Did I miss something??
    Thanks in advance for any help. Very much appreciated!:)
    #344117
    Dear cdboutique,
    Maybe you some of your extensions caused your site loaded VERY SLOWLY,could you post your url here for checking ?
    cdboutique Friend
    #344197
    I have found that my website displays and loads correctly now in IE6 when i disable the JA SLIDESHOW module. I may just insert an image instead.
    (For reference the template i am using is JA Lead.)
    Thanks for your advice!:)
This topic contains 3 replies, has 2 voices, and was last updated by  cdboutique 14 years, 6 months ago.
