  • steenmf Friend
    #133926
    Hi all.
    I´ve encountered a problem where the right module-column “drops down”, to a level under the main content. See the problem here:
    http://www.neurosurgic.com/index.php?option=com_jreviews&Itemid=554
    It only shows up in IE6 (but as many of my customers unfortunately are using IE6 this is of concern to me) – and it only shows up on certain pages.
    Could it be that IE6 is misinterpreting width of main content or column? Would it help to play with width settings?
    This is very annoying – and I would be very grateful for any help or solution.
    Menalto Friend
    #273443
    You can find this here in the css file:
    #ja-containerwrap-c #ja-content {
    width:82%;
    And try to set it to a lower width if that helps.
    steenmf Friend
    #273454
    That did it! I set the width to 80% and now everything is fine in IE6. Thanks for your help!
    Menalto Friend
    #273468
    No problems, happy for you that it worked:)
This topic contains 4 replies, has 2 voices, and was last updated by  Menalto 16 years, 2 months ago.
