jamjodesign Friend
jamjodesign
- June 2008
- 14 times in 3 posts
April 5, 2009 at 7:35 pm #300185Yes I have had a look at this template and have checked to see if I am as up to date as I can be and it seems I am. As I think the latest download of JA Teline has 1.3.1 the following is the description in the module at least and on viewing them both they have the same fields etc:
Description: JA News module version 1.3.1 come with JA Teline II. JA News Frontpage should be installed to used with this module. JA News Frontpage is a part of JA News packages (JA News + JA News frontpage = JA News 1.3 and released with JA Teline II). For Userguide, please visit http://www.joomlart.com/forums/topic/ja-teline-ii-read-me-userguide/
jamjodesign Friendjamjodesign
- June 2008
April 5, 2009 at 7:37 pm #300187Can I ask you – does it definitely work in IE7 and IE8 for you in the blog layout section of the website? I just cannot see how this could be? I know it works if I used a smaller image than 600 x217 but I just dont want a wrapping of text anyways regardless of the size of the image.
folkbear Friendfolkbear
- December 2006
- 14 times in 8 posts
April 9, 2009 at 7:58 am #300655well the image i used is not that big, but the solution works for me… yes, in blog layout…
- June 2008
April 10, 2009 at 7:52 am #300785Thanks for the reply. You see you do need the image to be 600 wide so it takes up a full width of the page in the content area – or else you cannot recreate what is happening here. I can insert an image that is 500 wide and the text will go underneath the image – again this only applies to IE browsers – so it is annoying if you have a full banner image alright. :((
- June 2008
April 15, 2009 at 8:23 am #301352Shameless bump here, I presume there must be a simple answer to this somewhere???
- June 2008
May 26, 2009 at 10:16 am #305884Can anyone help me here – this must be happening on other peoples sites? I guess it would not happen if you did not use the full width for the image in the blog sections but this must be simlpe to solve. Everything suggested above does not work. I can show anyone the live thing incase they want to see it but all the screenshots explain it fully really.
Its just an IE issue. chrome and firefox and safari all perfect.
This topic contains 21 replies, has 2 voices, and was last updated by jamjodesign 15 years, 7 months ago.
