  • Skotte Friend
    #132788
    HI I just installed the 1.5 version of ja_edenite.
    In safari and FF it looks as it should, but in IE the entire top, down to and including the menusystem is missing?
    Please see attached image:
    #268159
    Can you give us your live URL, any screenshot or more details of the problem will be helpful
    Skotte Friend
    #268174
    <em>@nguoiabcd 76919 wrote:</em><blockquote>Can you give us your live URL, any screenshot or more details of the problem will be helpful</blockquote>
    I work on a local MAMP installation, so the site is not public available, sorry 😮
    maisha Friend
    #268225
    I am having a similar problem.
    The logo/header has disappeared from my JA Edenite template.
    This is happening in FireFox 2.0.0.16 and IE 6.0. I am on a PC.
    I’m using Joomla 1.5.6.
    I have not modified the template – this is a fresh template install.
    Installed modules: template chooser
    Please provide a (non-public) address/place where I can send a URL. FireFox screenshot is attached.
    Thank you!
    1. MissingLogo
    Skotte Friend
    #268345
    I simply started over, and now it works. I don’t know what caused the problem though.
    /skotte
    xspolymers Friend
    #268533
    Most of the time these problems occur when you do not upload/FTP the template in binary mode. Hope this helps.
    Otherwise the JA templates are pretty flawless, with minor glitches here in there.
    They do however have a problem with including the extensions in the download, LOL.
This topic contains 6 replies, has 4 voices, and was last updated by  xspolymers 16 years, 3 months ago.
