November 14, 2006 at 3:46 am #117633
I still didn’t install ie7 but noticed a problem on my friends computer.
on 100% view, menu starts to be unqeual and search box goes down (however, on zoom 125% everything fine)
to illustrate the problem, I attached the image
does anyone have a suggestion on how to correct that?
November 14, 2006 at 4:55 am #211640k, i installed ie7 – it’ a rendering problem all around, but since 100% is most important:
just to correct my last post, – its not a menu problem:
logo moves down and covers menu buttons, search field also moves down out of its box
seems like a positioning problem (demo of regularis here also has the same problem)
November 14, 2006 at 7:30 am #211641I have noticed the same problem! How can this be solved???:confused:
Winston
November 16, 2006 at 4:28 pm #211725Hi,
I am also having the problem since the IE7 upgrades. Fine in Mozilla, but not in IE7. Can someone from Joomlart please solve the problem with this template and tell us all how to fix it and make it ‘IE7 proof’.
Many thanks
Rob (UK)
November 16, 2006 at 11:36 pm #211733This problem has been reported in earlier thread but no answer…
http://www.joomlart.com/forums/topic/search-box-on-regulus-ex-position/
would love an answer to this one please
ha le-viet Developerha le-viet
- April 2006
- 5 times in 1 posts
November 17, 2006 at 4:15 am #211741Hi mates,
Bugs have been fixed. Please re-download the template. If you did modify the template, please update only the template_css.css or find this CSS markup:
/* HEADER
#ja-header {and remove the line
line-height: 69px;
Regards,
Ha Le-Viet.November 17, 2006 at 8:45 pm #211777Great ffix – worked a treat.
Many thanks
November 18, 2006 at 8:00 pm #211823Thanks a lot, it worked great for me too.
November 19, 2006 at 7:58 am #211828🙂 thanks indeed work like a charm
November 23, 2006 at 12:13 pm #211961Hi mates,
/* HEADER
line-height: 69px;
Regards,
Ha Le-Viet.</blockquote>
Yes, this worked for me also.Many thanks.
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 5 voices, and was last updated by robbyboycar 18 years ago.
IE7 rendering problem
