  • vangeem Friend
    #140307
    I’ve upgraded to Internet Explorer 8 and now the mesolite template has some positioning problems.
    For example the ‘basket’ module is positioned left outside the templates lay-out. (see image)
    A second error is that my sites logo at the bottom left corner of the template isn’t displayed correctly.
    IE8 comes with compatibility display, if I push that button the layout is correct. I assume that most non-pc minded consumers will use this button so it would be great to see the mesolite template being updated to be fully compatible with IE8
    Phill Moderator
    #301594
    It has been upgraded. Just download the latest version of the template from the downloads section.
    vangeem Friend
    #301597
    is it possible to know which files i should update (i changed some code)
    Phill Moderator
    #301600
    You’ll have to ask JA on that one as there is no changelog.
    jose vega Friend
    #301603
    There is something that this failing in the you temper yourself Ja teline II, with the navigator IE8.
    Please, they have some solution of the problem.
    Thank you.
    To see problem
    http://www.plagasexpress.es/problemtemplate.jpg
    vangeem Friend
    #301687
    I had a look to the latest update of the template and according to the version number i’m allready running on v1.2 (date 25 july 2008). The version you can download is also v1.2, but I gave it a try anyway and in the css folder there is a file called ‘ie8.css’ that i didn’t have on my live site.
    I uploaded this ie8.css file, without any luck.
    Can anyone give me a solution?
    Phill Moderator
    #301693
    I’ve not tested but make sure you have the following in your templates index.php
    <link href="<?php echo $tmpTools->templateurl(); ?>/css/ie8.css" rel="stylesheet" type="text/css" />
    If that doesn’t work and JA do not help then you will need to use a diff viewer to find out the differences between the two template versions.
This topic contains 7 replies, has 3 voices, and was last updated by  Phill 15 years, 8 months ago.
