  • marcc Friend
    #143458
    in IE8, the logo appears in the wrong spot. Here’s a link:
    http://94.75.226.227/~bart01/index.php
    I’ve added this tag: <meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
    The funny thing is, it displays fine in IE7.
    Anny suggestions?
    Thanks,
    Marc
    ps5t0ck5 Friend
    #315271
    I’ve just checked and it looks ok now in IE8 – safe to assume you fixed the problem?
    marcc Friend
    #315987
    Thanks for pointing that out. As a matter of fact, I din’t fix anything!
    It’s a complete mistery to me why it’s working now. :confused:
    mfcphil Friend
    #316000
    adding the <meta http-equiv=”X-UA-Compatible” content=”IE=7″ /> will make it appear correctly in IE8
    Manos Moderator
    #316003
    Yes it will but what it does is (turn on the compatibilyty mode)
    mfcphil Friend
    #316004
    In IE8 there is a compatability button which will make your website appear as it does in other IE browsers, such as IE7.
    Adding the code will do the above automatically, so your web visitors need not press the compat button!
    Hope this helps explain 😉
    marcc Friend
    #316030
    The funny thing is, I added the tag you mention, but it didn’t seem to help. Propbably should have restarted IE or something.
    tfernandez Friend
    #316034
    I’m having the same problem with JA Quartz, not a logo placement issue but other allignment issues. I’m looking to automatically enable compatibility mode…sorry to have to ask this but where exactly do I add this meta tag code to do this?
    Thanks in advance.
    marcc Friend
    #316036
    Put in the <head> tag, at the top. That should do it.
    tfernandez Friend
    #316037
    ok done, will you please check it and let me know if fixed?
    http://www.southbeachmiamirealestatehome.com
    Thanks.
    marcc Friend
    #316038
    Looks fine here 🙂
    ps5t0ck5 Friend
    #316133
    marcc;142902The funny thing is, I added the tag you mention, but it didn’t seem to help. Propbably should have restarted IE or something.
    Hi marcc
    It probably didn’t update straight away – servers not always as quick as we would like!
    ps5t0ck5 Friend
    #316134
    tfernandez;142911ok done, will you please check it and let me know if fixed?
    Thanks.
    Yep looks ok in IE8 – some people have used the IE8 compatibility plugin, but this causes problems with some templates – some then aren’t compatible with IE7, so I understand.
    Caleb Tseu Friend
    #318828
    Sorry to ask this,
    Which file we modify to add in the code:
    Thanks:confused:
    ps5t0ck5 Friend
    #318907
    If you’re using ftp you can update the template index.php by adding the line into the area <menu head> find it in your website folder/templates/yourtemplate/index.php
    or via the template admin panel by going into extensions/template manager/your template/ and edit the html file.
This topic contains 15 replies, has 6 voices, and was last updated by  ps5t0ck5 15 years, 3 months ago.
