  • maxkaa Friend
    #195966
    Hi All,
    i have a problem with IE 8 browser with my t3 website at http://test.agenas.it.
    Any ideas to solve this problem ?
    I have to golive on next tuesday and i can’t figure out how to solve the problem.
    Thanks in advance
    I see the problem comes from CSS3 that your ‘Agenas’ module uses to set the background:
    .agenas-sfondo-blu {
    background-image: linear-gradient(#095FFF,#003893)
    background-repeat: repeat-x;
    background-color: rgb(91,149,255);
    Unfortunately, IE8 doesn’t support gradients of the CSS3 variety so it looses background color when viewing in IE8.
    You can try a tweak here: http://coding.smashingmagazine.com/2010/04/28/css3-solutions-for-internet-explorer/ (scroll down Gradients syntax section).
    maxkaa Friend
    #527656
    Thank you Saguaros but the problem is that logo header div is pushed on the left margin of the page and Page is not responsive. For the CSS thank you i’ll try the trick
    The logo part seems to look fine at my end: http://prntscr.com/33llgq
    Could you please send me screenshot to illustrate how it should be?
    maxkaa Friend
    #527925
    Saguaros thank you very much, the site is now published , the problem was in the way i use the ie11 Emulation mode
This topic contains 5 replies, has 2 voices, and was last updated by  maxkaa 10 years, 9 months ago.
