  • dgruebner Friend
    #145511
    I am currently working on a site using the Cooper Business Template.
    I experienced major problems with my site using the Internet Explorer 8. As you can see right here, the slideshow on position “ja-slideshow” is laying right over the main content. I don’t have these problems using Firefox, an older version of the IE or the compatible mode: http://www.heb-ra.com/heb
    Joomla-Version: 1.5.14
    Installed Components: JCE Editor, JoomFish
    I just uploaded the original template files but it looks the same. Would be great if somebody can take a look at.
    Firefox (everything’s fine):
    IE8 (looks like the background is not loading correctly):
    Thank You
    Edit 14th Dec.: Fixed, see last post
    Anonymous Moderator
    #321696
    Hi dgruebner
    I have tried to find your issue but could not find. It is readly worked fine
    I have sent you an attachment which i saw your website at my browser.
    1. IE8
    dgruebner Friend
    #321709
    when I enable the “compatibility mode” in IE8, it looks the same. But this mode is for older websites. If have to push a button on the right side of the address input in my browser to get the correct view of the site.
    Thanks.
    dgruebner Friend
    #326079
    I can still not solve this problem. I made a video of what I will see when I load up the page.
    http://www.heb-ra.com/heb/Template_prob_high.wmv
    Anonymous Moderator
    #326249
    Hi dgruebner
    I could not view your website for checking at this time. I saw this notification:
    404 – Komponente nicht gefunden!
    I think you are modifying your website.
    Please let me know if your modification is complete.
    dgruebner Friend
    #326273
    <em>@JA Developer 156380 wrote:</em><blockquote>Hi dgruebner
    Please let me know if your modification is complete.</blockquote>
    I modified the first post and the Login-data. Site was already moved to another server. Check again please.
    Anonymous Moderator
    #326459
    dgruebner Friend
    #326558
    Thanks! Works fine now.:)
This topic contains 8 replies, has 2 voices, and was last updated by  dgruebner 15 years, 1 month ago.
