  • netizmir Friend
    #194747
    JA Masshead Right-top Block Problem
    help please
    web adress
    http://www.inonucaddesi.com
    1. p1
    2. p2
    3. p3
    swissa Friend
    #522539
    Can you describe the problem and what you are looking to achieve. On the module check your module suffixes. If you don’t want the colour behind don’t use ‘highlight’. If you don’t want padding don’t use the ‘big padding’. Is that what you mean?
This topic contains 2 replies, has 2 voices, and was last updated by  swissa 10 years, 10 months ago.
