September 26, 2009 at 5:50 pm #144624
if i put an image in an article using jce editor, and i publish it in home, the article is display in to body, but tex are in to body, image are outside of the template.
If i open article is all ok, but when it is displayed in to body in home image are outside.What i must do?
- 2008 times in 1700 posts
September 28, 2009 at 10:42 am #318873Hi wlfmarcus
Could you please send me your live url, admin account via PM so that i could have a closer look on the issue?
September 28, 2009 at 11:00 am #318876ok thank you
September 29, 2009 at 3:46 am #318948Hi wlfmarcus
Thank you for your PM.
I have tried to login to your administrator to check your issue but could not log in.
Please kindly check your account again.
September 29, 2009 at 10:07 am #318994ok sorry, i have ripristinate a backup yesterday, and your account there aren’t in backup, now i have riprisitnate your account user and password are the same of pm.
Thank you
September 30, 2009 at 7:53 pm #319204The problem seems to remains for a lot of us. I’ve got the solution by making a new category blog (category = frontpage) instead of the standard frontpage blog. Of course is it a temporary solution until they come with a technical and permanent solution.
Frank
September 30, 2009 at 7:59 pm #319206i have try using other template, and the image is display in to body, but in ja quartz no 🙁
i don’t understand what i must do, can use word more simple, or sed me
find in this in template/ja quartz and copy this code then this.Thank you
malestorm Friendmalestorm
- December 2007
- 3 times in 1 posts
October 3, 2009 at 2:56 pm #319459Just to confirm, this is an outstanding problem that I have had with Quartz also.
Here is what I have found:
– The problem has nothing to do with JCE. Regardless of which editor you use to insert an image into an article, the article still ends up positioned at the top left of the webpage.
– I disabled almost every extension and disabled the top menu so that the only thing appearing on my frontpage was one article with an image. The image still displays upper left corner of the .
– The problem occurs regardless of which browser one users.
– The problem occurs regardless of which attributes you add to the image.October 4, 2009 at 8:40 pm #319524yes, jce is not the cause,
broswer is not the cause,
and if i open Article in Article page, image are display correctly.
if i change template, image are display correctly also in body in home pageplease help me, for me is very important, pubblish image in body in home page
thank
October 7, 2009 at 8:13 am #319719Hi wlfmarcus
For this case, in administrator, please go to Menus -> Main menu -> edit the default item. In the edit page, please enter _fp into Page Class Suffix textbox of Parameters (System) tab.
Hope it helps.
1 user says Thank You to JA Developer for this useful post
October 7, 2009 at 11:39 am #319741hi,
now the image are displayed in to body, but is display always in position: top-right also if i put at the end of artcile, and image is also distorted and so incomplete, and the tex don’t use all space.
however is a good step.
now how can fix this bug?i have post a screenshot.
Thank
October 10, 2009 at 2:14 pm #320106I have the same problem…
How I can solve it? I have tried _fp in suffix but it didn’t work.
I’m using Ruby template.
My website is http://www.datinetweb.comOctober 12, 2009 at 7:47 pm #320279please help, for me is very very importan publish image in body in home page
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 5 voices, and was last updated by wlfmarcus 15 years, 2 months ago.
Image in to Body in home, diplayed outside
