December 10, 2015 at 12:45 pm #794783
Hi!
I decided to use MagzII template on my magazine website. I used K2 before, but I’m ready to return to standard contents.
I bought K2 Migrator to convert all my articles back, I tested it on a sample and two errors seem to exist:- K2 articles are imported into content, in the admin I can see the images as well, but on the site they disappear (pls. see in: http://magz.rehabportal.hu/)
- I used extra fields in K2 for author and source, so it’s important to see this contents in the articles. Please be so kind and help me with the implementation, because at the moment they disappeared from the site.
Thank you in anvadce for your kind help!
- November 2014
- 3854 times in 3563 posts
December 11, 2015 at 5:14 am #801656Hi,
I report it to the development team for further checking, you can track its status here.
Beside that, you can provide me the admin login info of your site again by putting info in your reply and SET AS PRIVATE reply (so that only Moderators and Staffs can see). Our dev will check it on your site.
December 11, 2015 at 8:31 pm #805946This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
December 15, 2015 at 10:39 am #814661Our dev has checked the problem on your site, but they could not find the problem of your mentioned above, you can let me know steps to get both the problems on your site. They will help you out.
December 15, 2015 at 1:46 pm #815040Dear Ninja Lead!
Please re-check the issue as I try to describe it step-by-step:
- k2migrator plugin finishet it’s job
- old k2 article created in com_content
- article image also moved to com_content and present in article (for example: http://magz.rehabportal.hu/index.php/63-hirek/munka/3459-uj-foglalkoztatasi-rehabilitacios-epuletet-adtak-at-pecsen)
- but as you can see in the main page (http://magz.rehabportal.hu) the image of same article (first is "Business" section) is missing
The other part of my prev. question:
- k2 migrator converted my k2 extra field into com_content
- they are exist in the admin area to see and edit
- hogy can I make them appear in article view (I think some kind of php code is needed)
Thank you in advance!
- November 2014
December 16, 2015 at 9:56 am #816505I spent a lot of time to debug the problem on your site and hope my explain below will help you to get the problem on your site.
The article here Új foglalkoztatási rehabilitációs épületet adtak át Pécsen with content type forras_adatok not article
- I added the image into Akadnak, akik elvárnák, hogy depressziós legyek, amiért nem tudok járni, de én imádok élni with content type article, you can see the image is showing on your site (I am enabling content type to show on your site and will disable it)
If you want to show the image into Alternative Layout with articlelist layout, you need to choose content type with article.
December 6, 2016 at 11:27 am #992567Dear Ninja Lead!
I came back to this issue and I understood your explanation, but regarding this I still have two questions:
How can I change the content type of an existing article to "article"?
What’s more important: am I able to change this in 300 articles with a batch movement or I have to do it (if possible) one by one?Thanks in advance for your kind help!
- November 2014
December 7, 2016 at 8:08 am #992831Hi,
Thanks for your back.
About the your request, I think the best way you can go to phpMyAdmin and find the #___content table:http://prntscr.com/dgcohb and change all the article items from attribs field and remove "ctm_content_type":"gallery" and "ctm_content_type":"video": http://prntscr.com/dgco27
Please make a backup version before doing changes
This topic contains 7 replies, has 2 voices, and was last updated by Ninja Lead 8 years ago.
