  • kbfrench Friend
    #126563
    Thanks to Menalto, I was able to get the Teline QuickStart up & running. I am now experiencing another issue.
    Anytime I add a new article, the article is properly displaying within the proper category on the home page. However, the image that is in my article, is not being added on the home page, but it does exist on the article page.
    I am using the JCE editor and Joomla 1.5.
    Any help??
    thanks
    ddegraw Friend
    #242304
    Hi guys I had the same exact problem. I’m also using Joomla 1.5 and also need some help.
    Thank you
    klazebaas Friend
    #242408
    I have the same problem as well. by the way is it possible to put a standart image in front of the different categories? I can’t do that either.
    kbfrench Friend
    #242424
    I have realized that this is related to the “auto resize image” option in the JA_News module. If I have auto resize enabled (which I would obviously like to), the <img> tag is being omitted completely.
    Can someone please help resolve this issue.
    klazebaas Friend
    #242552
    Ok so what I found out is that if you create a table of 2 cells and you put the image in one and the text in the other, you can place whole thing in the text field and it will show both, steady and set.
    If it makes more sense, try to take a RSS feed from Google and select a random article with picture. You’ll see what I mean. I think this is the fastest way to deal with the prob.
    However if someone knows the normal way please keep us posted 😀
This topic contains 5 replies, has 3 voices, and was last updated by  klazebaas 16 years, 8 months ago.
