test melih
 melih
  • girishnuli Friend
    #146717
    When 2 or more images are added in an article, the images are stripped out and a slideshow is created at the top. How can this be stopped?
    The “Read more” button/link is not visible when it is added to an article. How can this be enabled?
    Thank you,
    Girish.
    Anonymous Moderator
    #326326
    Hi girishnuli
    could you submit a ticket, send us your live url, admin account so that we have a closer look on the issue?
    actswartz Friend
    #326682
    Add
    {jathumbnail off}
    to fix this issue.
    amsolutions Friend
    #326720
    <em>@girishnuli 156293 wrote:</em><blockquote>The “Read more” button/link is not visible when it is added to an article. How can this be enabled?</blockquote>
    There are a few places you have to try to fix this:
    On the menu item that links to the article(s) under Parameters (Component) select “Show” next to the Read more… link option.
    Go to the Article Manager and go to the global parameters to all articles and make sure that the radio button next to Read more… link is set to “Show” also.
    ^ If you do this, make sure that in the Parameters (Advanced) section for each article, each option is set to “Use Global”.
    I hope this helps 😀
    reders Friend
    #329305
    I have the same issue with the thumbnails, where/which file do you add {jathumbnail off}
    Regards,
    Reders
    actswartz Friend
    #329322
    using the built in article editor, add {jathumbnail off} to the beginning of each article that you want thumbnails turned off.
This topic contains 6 replies, has 5 voices, and was last updated by  actswartz 15 years ago.
