brusamolino Friend
brusamolino
- January 2009
- 10 times in 2 posts
May 14, 2014 at 12:09 pm #197762Hi
the images inside slideshow in homepage are not responsive…. when i resize the browser, images are cropped and not resizedCan you help me?
I’ve installed Ja Biz template on joomla 3.2.3 and ‘ve updated T3 framework at 2.1.6 version
thanks luca
alexsmirnov Friendalexsmirnov
- July 2012
- 163 times in 119 posts
May 14, 2014 at 8:41 pm #535216Hi there,
What is your web site URL please?
Regards,
Alex
brusamolino Friendbrusamolino
- January 2009
May 14, 2014 at 8:48 pm #535219brusamolino Friendbrusamolino
- January 2009
May 15, 2014 at 10:27 am #535296Somebody can help me?
thanks
Lucaalexsmirnov Friendalexsmirnov
- July 2012
May 15, 2014 at 10:40 am #535297Hi Luca,
Could you please PM me your Joomla Super User credentials to have a look around your system?
Regards,
Alex
- January 2009
May 15, 2014 at 11:03 am #535299i’ve sent you in private msg
thanks luca
- January 2009
May 20, 2014 at 9:03 am #535837any solution?
thanks luca
- July 2012
May 22, 2014 at 12:42 pm #536225Hi Luca,
Sorry for keeping you waiting. I referred the question of JA Slideshow responsive behavior on JA Biz to our developers. Please bear with us.
Regards,
Alex
March 28, 2016 at 3:07 pm #905700Any answer to this?
- November 2014
- 3854 times in 3563 posts
March 29, 2016 at 2:41 am #905974http://www.dot360.it/stil4/%5B/quote]
JA Slideshow module on JA Biz template does not support responsive and it disabled on the mobile device, but I will try to find the solution for you.
Please give me the URL of your site and the dimension(width and height) of what do you expect?
March 29, 2016 at 2:08 pm #906251I don’t have a specific size requirement other than the images should scale down. I don’t mind that they drop out at the smallest size.
The same should be true for the navigation bar on the left as well as the text that overlays the photo. These elements should somehow translate responsively on the smaller devices.
- November 2014
March 30, 2016 at 4:11 am #906492@nysfda: This way will help you out
Create templates/ja_biz/css/custom.css file and add new rule
@media (max-width: 767px) { .ja-slide-main-wrap .ja-slide-main .ja-slide-item img { width: 100% !important; height: 100% !important; } .ja-slide-thumbs, .ja-slidewrap .maskDesc .ja-slide-desc { display: none !important; } }
This topic contains 11 replies, has 4 voices, and was last updated by brusamolino 8 years, 8 months ago.
