  • nasdam Friend
    #203442
    I have a problem with my site: http://screenjuss.com/
    If you scroll past some articles present in there the images will not be loaded. Only the first 5 articles are presenti, 5 was the value I picked in the Menu Item for the number of Articles to be shown, so after that the dynamic scrolling is working but not loading images. I’ve checked the tags are correct but they just aren’t loading, and I can’t find if this is a js issue or anything of that sort.
    Best Regards,
    Thank you for any help
    Ninja Lead Moderator
    #558099
    JA Argo template was conflicted with JA System Lazyload plugin, I disabled it the problem on your site is gone.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 10 years ago.
