  • sw82 Friend
    #179394
    Hi I have created an article using the jce editor. I have added images to the article and aligned them to the left of each subheading, yet all the images are bunched together with a next and previous link.
    I would like to images to show up where I have put them and i’m not sure how to do this.
    Thanks for any help 🙂
    http://www.hairdetective.co.uk/hair-style-advice/hairstyle-advice/face-shapes
    Hi there,
    Maybe the JA Thumbnail plugin is currently installed in your site now and by default, this plugin is often enabled with Integration mode: auto so that if there are some images in that article, they will be bunched like above. The following is 3 integration mode used in this plugin, you can make a choice:
    – “Auto” mode: JA Thumbnail Plugin is enabled automatically in all Joomla articles. To turn off this feature for specific articles, use the {jathumbnail off}tag in that article.
    – “Manual” mode: To enable JA thumbnail plugin for an article, you must place {jathumbnail} somewhere in your articles content.
    – “Disable” mode: Disable the Thumbnail generation (DO NOT use the Disable feature of Joomla if you have used the tag {jathumbnail} or {jathumbnail off} already. It will be parsed as normal text.
    Hope this helps you.
    sw82 Friend
    #462325
    Yes that worked, thank you 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  sw82 12 years, 5 months ago.
