March 16, 2010 at 9:50 am #336410Dear annaleen!
i have created a account on your site, my account is tienhc (@email: tienhc@joomsolutions.com) Thanks
annaleen Friendannaleen
- April 2007
- 13 times in 1 posts
March 16, 2010 at 12:57 pm #336427Thank you tienhc, I don’t know what you did but it looks better (no changes to the plug-in), only problem is all align left would like auto (left and right) as in original document, would that be possible?
Kind Regards
AnnaleenSaguaros ModeratorSaguaros
March 17, 2010 at 8:14 am #336551Dear annaleen!
i changed the design of the front-page same as the Blog layout and did small changes of some styles in the template.css.
With the front-page layout and the blog layout,: the Image only display on the left side.
With the article layout: allow the image change the “left” side or “right” side follow two paramters of the JA THUMBNAIL plug-in:Integration Mode :
Image align:annaleen Friendannaleen
- April 2007
March 17, 2010 at 2:34 pm #336614Thank you tienhc, is it also fixed in the new version, ’cause I still need to upload latest template but want to wait untill enverything is fixed? 😉
March 18, 2010 at 8:10 am #336744Dear annaleen!
if you would like the to upgrade the template with the last version, pls kindly backup for me the following files:
1) templatesja_rasitehtmlcom_contentfrontpagedefault_item.php
2) templatesja_rasitecsstemplate.css fileyou ‘ll use a compare software to view theirs differences and move my changes to new files. i make sure that it will be worked
if you have any problems pls post in here or send a message to my email “tienhc@joomsolutions.com”, i ‘ll start work immediately 🙂 on your issues
tphmedia Friendtphmedia
- July 2009
- 2 times in 1 posts
March 22, 2010 at 12:27 am #337115Enable the plug-in…(JA thumbnail). Then change the settings as follows:
Scroll down to Thumbnail for Blog View, enable this and size images to 60×60 (or whatever you want)
Click YES to apply to homepage.
It works perfectly!
This topic contains 22 replies, has 4 voices, and was last updated by annaleen 14 years, 8 months ago.
