  • paoloci Friend
    #204688
    I use Ja Wall with the theme blackboard for subsite no-profit site.
    Usually I put “dark” or “hilite” or my own colour class in the article. Ordinary all play well.
    Not in this site. But i don’t understand why.
    I update the information, all the sites where I use Ja Wall have joomla 3.4 and no conflict is present for this operation of override the class.
    I haven’t change the css file of the theme.
    Do you any idea?
    This is the site
    http://catechesi.diocesifrosinone.it/
    Thanks for suggestion and contribute.
    paoloci Friend
    #563149
    I have found the problem..
    in the article is not present extendend class.. is missing.
    So I put the class in the wrong box.
    I must recover this form extendend class. In which way I can recover?
    Upload the last joomla version and overwrite the folder administrator?
    paoloci Friend
    #563228
    Please see the attachment.
    Both site are in Ja Wall
    could be so
    but it’s in this way
    thanks
    1. extended-classes
    2. missed-extended-classes
    Ninja Lead Moderator
    #563245
    @paoloci: I’m not sure what did you config from backend of your site? But you can try to follow the userguide here for more info.
    Hope it helps
    paoloci Friend
    #563257
    I think
    more certainly
    depend from the Ja wall template.
    Because seems extended classes is not present by default in the core of joomla.
    #563336
    <em>@paoloci 463652 wrote:</em><blockquote>I think
    more certainly
    Because seems extended classes is not present by default in the core of joomla.</blockquote>
    You can PM me the credentials of your site i.e: admin and FTP account. I will check it directly on your site.
    paoloci Friend
    #563391
    Done, thanks
    paoloci Friend
    #563536
    Thanks for solved. I need to know which was the problem.
    So The possibility of use of the extended classes have solved (partially) also the other post Leave in blog vision the original formatting of the article.
    #563554
    <em>@paoloci 463824 wrote:</em><blockquote>Done, thanks</blockquote>
    I just enabled JA System Pager plugin directly on your site, I don’t know why it was disabled on your site. Now, you can check it from Article and see it’s displaying on your site
    1. Screen-Shot-2015-03-18-at-12.49.21
    paoloci Friend
    #563563
    Sorry,
    sometimes the big question have a simple a small solution.
    Thanks again
This topic contains 10 replies, has 2 voices, and was last updated by  paoloci 9 years, 10 months ago.
