  • kooljp Friend
    #147820
    Hi all
    Installed JA Purity II on my site http://www.thefind.com.au
    Home page looks perfect, but ALL other pages (links) appear without the Template design.
    They show content only.:confused:
    What have I done wrong?
    Here is my index.php file:
    <?php
    JA Purity II for Joomla 1.5
    #Copyright (C) 2004-2009 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
    #@license – GNU/GPL, http://www.gnu.org/copyleft/gpl.html
    #Author: J.O.O.M Solutions Co., Ltd
    #Websites: http://www.joomlart.comhttp://www.joomlancers.com
    // no direct access
    defined( ‘_JEXEC’ ) or die( ‘Restricted access’ );
    include_once (dirname(__FILE__).DS.’libs’.DS.’ja.template.helper.php’);
    $tmplTools = JATemplateHelper::getInstance($this, array(‘ui’, JA_TOOL_SCREEN, JA_TOOL_MENU, ‘main_layout’, ‘direction’));
    //Calculate the width of template
    $tmplWidth = ”;
    $tmplWrapMin = ‘100%’;
    switch ($tmplTools->getParam(JA_TOOL_SCREEN)){
    case ‘auto’:
    $tmplWidth = ‘97%’;
    break;
    case ‘fluid’:
    $tmplWidth = intval($tmplTools->getParam(‘ja_screen-fluid-fix-ja_screen_width’));
    $tmplWidth = $tmplWidth ? $tmplWidth.’%’ : ‘90%’;
    break;
    case ‘fix’:
    $tmplWrapMin = $tmplWidth ? ($tmplWidth+1).’px’ : ‘771px’;
    $tmplWidth = $tmplWidth ? $tmplWidth.’px’ : ‘770px’;
    break;
    default:
    $tmplWidth = intval($tmplTools->getParam(JA_TOOL_SCREEN));
    $tmplWrapMin = $tmplWidth ? ($tmplWidth+1).’px’ : ‘981px’;
    $tmplWidth = $tmplWidth ? $tmplWidth.’px’ : ‘980px’;
    break;
    $tmplTools->setParam (‘tmplWidth’, $tmplWidth);
    $tmplTools->setParam (‘tmplWrapMin’, $tmplWrapMin);
    //Main navigation
    $ja_menutype = $tmplTools->getParam(JA_TOOL_MENU, ‘css’);
    $jamenu = null;
    if ($ja_menutype && $ja_menutype != ‘none’) {
    $japarams = new JParameter(”);
    $japarams->set( ‘menutype’, $tmplTools->getParam(‘menutype’, ‘mainmenu’) );
    $japarams->set( ‘menu_images_align’, ‘left’ );
    $japarams->set( ‘menupath’, $tmplTools->templateurl() .’/ja_menus’);
    $japarams->set(‘menu_images’, 1); //0: not show image, 1: show image which set in menu item
    $japarams->set(‘menu_background’, 1); //0: image, 1: background
    $japarams->set(‘mega-colwidth’, 200); //Megamenu only: Default column width
    $jamenu = $tmplTools->loadMenu($japarams, $ja_menutype);
    //End for main navigation
    $layout = $tmplTools->getLayout ();
    if ($layout) {
    $tmplTools->display ($layout);
    kooljp Friend
    #329899
    SOLVED:
    My hosting provider was kind enough to provide a solution:
    The issue was caused by the fact the Joomla SEF functionality was only partially enabled.
    To enable it completely, I have renamed htaccess.txt to .htaccess and set the following variables in configuration.php:
    var $sef_rewrite = ‘1’;
    cheers
    kooljp
This topic contains 2 replies, has 1 voice, and was last updated by  kooljp 14 years, 10 months ago.
