doparedes07 Friend
doparedes07
- May 2012
- 3 times in 1 posts
Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
July 12, 2012 at 11:36 am #460711Hi doparedes07,
I have checked on your site and see that you the infinite-scroll work well.
There is an error alert that say
‘Line: 30
Error: ‘SqueezeBox’ is undefined’This error happened because you have modified the Joomla core.
I would never recommend you to do it.Please check again.
doparedes07 Frienddoparedes07
- May 2012
July 13, 2012 at 12:54 pm #460833<em>@Wall Crasher 329782 wrote:</em><blockquote>Hi doparedes07,
‘Line: 30
I would never recommend you to do it.Please check again.</blockquote>
Hi Wall Crasher
I did a fresh install in this link and the problem is the same please check itdoparedes07 Frienddoparedes07
- May 2012
July 13, 2012 at 2:24 pm #460839Here’s same caption of the issue in a new installation here’s the link to new site
Wall Crasher
- December 2011
July 16, 2012 at 6:41 am #460986Hi doparedes07,
The infinity-scroll is working property but IE seem have some strange behavior.
Please use the attachment, overwrite file templatesja_walljswall.js and check if it work on your side.
🙂Hope it help.
1 user says Thank You to Wall Crasher for this useful post
- May 2012
July 16, 2012 at 12:27 pm #461041<em>@Wall Crasher 330169 wrote:</em><blockquote>Hi doparedes07,
🙂Hope it help.
Regards</blockquote>
Seems that was the problem, I’d change the file with the attachment and now works fine!!!!
Thanks a lot
Viewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by doparedes07 12 years, 6 months ago.
