  • jm1100 Friend
    #208884
    Hi again guys,
    Hope your fine.
    I’ve been looking for some thread about it but I didn’t found anything.
    So here is my issue : I wonder how to display one entire article in uber-business layout, without including it in a ACModule, mainly for SEO issues.
    And if possible, to do it before “business-home” position.
    This is about using joomla in a classic and easy way : article, category and item menu “Article”.
    There is a “message” position in this layout, but it doesn’t display anything.
    If I use another template for this menu item, header and footer disappear obviously…
    Thanks for your help.
    JM
    Adam M Moderator
    #577808
    Hi @jm1100,
    Assuming that you’re using layout home-business, please open file templatesubertplshome-business.php and look for this part :
    <?php $this->loadBlock('home') ?>
    <?php if($this->hasMessage()) : ?>
    <div class="container">
    <jdoc:include type="message" />
    </div>
    <?php endif ?>
    then change as below :
    <?php $this->loadBlock('mainbody') ?>
    Adam M Moderator
    #644102
    Hi @jm1100,
    </div>
    <?php endif ?>
    Adam M Moderator
    #742737
    Hi @jm1100,
    </div>
    <?php endif ?>
    jm1100 Friend
    #577815
    Works perfectly 😀 *Infinite thanks*
    Just a detail : it creates a space between the mainmenu and the first module in the other pages :
    Is it possible to avoid it ?
    regards,
    JM
    jm1100 Friend
    #644109
    regards,
    JM
    jm1100 Friend
    #742744
    regards,
    JM
    Adam M Moderator
    #577946
    Hi @jm1100,
    In this case, please duplicate file home-business.php and named it home-business-custom.php. Use layout home-business-custom in your home page, revert changes in file home-business.php and use it for all the rest.
    jm1100 Friend
    #577994
    Perfect !
    Thanks 🙂
    jm1100 Friend
    #644285
    Perfect !
    Thanks 🙂
    jm1100 Friend
    #742918
    Perfect !
    Thanks 🙂
This topic contains 11 replies, has 2 voices, and was last updated by  jm1100 9 years, 5 months ago.
