Viewing 1 post (of 1 total)
  • crown777 Friend
    #174016
    It is necessary for me to create the top frame and to transfer there top.absolute, top.mainnav, top.header, top.top-panel. The total design should look following In the image:
    main menu is possible in two variants:
    • It is built in in opening panel-slider (probably use of cPanel)
    • Or a component of the top menu.
    I will be grateful if will prompt as …
    1. header
    2. menu
This topic contains 1 reply, has 1 voice, and was last updated by  crown777 12 years, 9 months ago.
