  • olijo Friend
    #942173
    I tried to install quickstart here : http://btfl.info/hl/ Result seems to be totally brokken. Any idea what could be the problem ???
    Pankaj Sharma Moderator
    #942248
    Its seems the package is not successfully installed . I suggested you to download the fresh package again and install it on a Fresh DB with Sample Data .
    olijo Friend
    #942299
    Already tried 4 times, are you sure the package is not damaged ?
    Regards,
    Olivier
    #942325
    Just downloaded the fresh package of Teline V and install it on my localhost , it installed fine , no issue faced .
    http://prntscr.com/biyq1j
    Please make sure you are installing the sample data : http://prntscr.com/biyo16
    Let me know if still having issues .
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 4 months ago.
