  • andy55 Friend
    #977102
    hello everyone i’m about to install jarent. and i have some questions
    there is no help about "about us " and "contact us" page how can i do that?
    the acm module on home page doesen’t show intro text
    best regard
    Ninja Lead Moderator
    #977418
    You can provide the credentials of your site: URL, Admin account so I will have a look and check for you.
    andy55 Friend
    #977668
    hi
    at the moment is not on a public host but on our internal server
    Andrea
    #977927
    In this case, you can refer the configuration from our documents here
    This will help you to create the contact page modules . If you would like to check the settings of each module/menu , you can install the quickstart package on your localhost and check the configuration , then apply same on your development site .
    andy55 Friend
    #984749
    hello again
    it seems that feature intro of acm module doesn’t work correctly, how to solve?
    Andy
    #985013
    It’s very hard to suggest the solution for you without clue to see the problem on your site. Please put your site to go Live and please give me the credentials info via private reply. I will help you out
    andy55 Friend
    #985190
    intro is not visible, but in this moment website is only local, i think it’s a bug.
    1. Appunti01
    #985330
    You can try to config the module as my screenshot: http://prntscr.com/d5jzsm and http://prntscr.com/d5k06b
This topic contains 7 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 2 months ago.
