  • iamwe361 Friend
    #948858
    Hell JA,
    I have a new install of Joomla 3.5.1
    I have attempted to install JA Wall unsuccessfully.
    I receive the following message ( seems there is a time out or the sys. is not recognizing the process ):
    This site can’t be reached
    The connection was reset.
    Try:
    Reloading the page
    Checking the connection
    Checking the proxy and the firewall
    ERR_CONNECTION_RESET
    I have uploaded other templates without problems. Ja Wall will be my main template for this site, so i need it to work.
    Your help is greatly appreciated.
    Thanks.
    Hi there
    Install template on an empty folder extracting quickstart package in it and then test it if it works or not , we installed hundreds of quickstarts without errors , so this is pretty your hosting issue or a wrong quickstart download, try to download again zip file.
This topic contains 1 reply, has 2 voices, and was last updated by  pavit 8 years, 4 months ago.
