  • flyboy83 Friend
    #141678
    I am installing the quickstart version of JA Vauxite and after installing, and previewing site, I saw that it has the following error:
    Parse error: syntax error, unexpected ‘=’, expecting ‘)’ in /homepages/46/d202274087/htdocs/thebizexpress/plugins/content/ja_tabs.php on line 31
    I looked in the plugin folder and in the content folder and there is no php file; ja_tabs.php
    I am using the newest version of Joomla; Joomla 1.5.10
    The URL is http://s202275129.onlinehome.us/thebizexpress/
    Please let me know what I am supposed to do about this?
    theprofessor Friend
    #306805
    I had the same problem today when I installed JA quartz.
    I found the JA-Tabs plug-in zip file in the Templates folder. I unzipped it in the same folder and everything worked fine.
    Let me know if that works for you.
    flyboy83 Friend
    #306807
    WOW! Professor, that was quick but unfortunately that did not work because it still does not have the ja_tabs.php file in it.
    Where did I get the file or is this not supposed to happen?
    I just disabled the plugin and module and now I am off and running. I guess until I get a fix, I will not be able to use ja_tabs features.
    Thanks, I thought it was going to work
    nguyenhuu quang Friend
    #306829
    hi, Unzip quickstart and Upload to your host again.
This topic contains 4 replies, has 3 voices, and was last updated by  nguyenhuu quang 15 years, 7 months ago.
