December 20, 2012 at 7:12 pm #183297
OS: Win7 64b
XAMPP: 1.8.1Problem:
when “installing” using “quickstart”, following happens:what is the problem?
For e.g. <ja_brisk> is working just fine using its quickstart.
Time does not allow me to do a manual install, and configure the template from scratch (I do this only for my site, I’m not a website developer). I paid for this, and it would be great to work, leaving me just to take care of changing it according to my needs…
Saguaros ModeratorSaguaros
December 24, 2012 at 1:28 am #477324HI vladdygo04,
You can hide this warning by going to Global configuration and set Error Reporting to None.
Regards.
December 24, 2012 at 8:20 am #477379Did that, but is not the solution!
Uninstalling K2 and reinstaling it form oficial website solved the problem. So there is sth wrong in “quicksetup”, I don’t have time to go deep to see exactlly what.
December 25, 2012 at 3:30 am #477455I shall check again to detect what problem is since I did install yesterday and it works properly in my local.
anyway, glad it works now 🙂 and let me know if you need further helps
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Saguaros 11 years, 9 months ago.
installation problem
