  • maxdoor Friend
    #195600
    After installation of Vintas template with quickstar i recive this error message when i try to enter in site.
    Fatal error: Call to undefined function mb_internal_encoding() in D:Inetpubwebsgardaboutiqueitcomponentscom_k2helpersroute.php on line 93
    What i can do ?
    Best Regards
    Your problem is related to your php settings you should have the mbstring enabled
    Ask to your hosting provider to switch your environment on php 5.3 version or enable the mbstring via php.ini file
    1. Screenshot_5
This topic contains 2 replies, has 2 voices, and was last updated by  pavit 10 years, 8 months ago.
