  • pabloguti89 Friend
    #197397
    I just installed the JA K2 Filter but aperantely it caused a faltal error with the following message
    Fatal error: Class ‘K2Table’ not found in /data/19/2/49/13/2864665/user/3151508/htdocs/TENGO_PROPIEDAD/administrator/components/com_k2/tables/k2user.php on line 14
    I try enabling all plugins and modules but it doesn’t work, i tend to think that it can’t call any user from the ones who already exist in the database.
    It will be great if you gan give any clue on how to fix this.
    Thak you
    Thanh Nguyen Viet Friend
    #533767
    Have you sorted this out? I just checked your site but could not see the issue you mentioned.
This topic contains 2 replies, has 2 voices, and was last updated by  Thanh Nguyen Viet 10 years, 6 months ago.
