  • austrocan Friend
    #128065
    I am trying to install this template and am given this error message
    <blockquote>Warning: zip_entry_read() [function.zip-entry-read]: The bytes parameter must greater then zero in /mnt/gs02/herd03/31095/domains/austrocan.com/html/en/libraries/joomla/filesystem/archive/zip.php on line 239</blockquote>
    What is this and why am I getting it?
    Aaron
    Menalto Friend
    #269320
    Did you manage to get this solved? If you did please mark this as solved, in not reply here and we will try to help you out.
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 3 months ago.
