  • checkmate40 Friend
    #128137
    When I try to install I get the following error…
    JInstaller::install: File ‘/home/content/s/*/*/*/html/SL/tmp/install_481a530b952b3/highslide/highslide-with-html-bak.js’ does not exist
    Its a fresh joomla install that I setup with the Corona Quickstart and installed the erica template.
    So far thats all I’ve done.
    Thanks.
    gt5gt Friend
    #247784
    Absolutely the same problem to me: installed fresh Joomla 1.5.3 and then installation of Teline II failed because of
    *.*.*/tmp/install_481ec46fdca94/highslide/highslide-with-html-bak.js” does not exist.
    Would be great to get a comment – hope Teline II is worth its prize… :confused:
    greets
    gt5gt
    edit: by the way: it’s definitely a specific problem of Teline II, because other templates (e.g. Teline 1) work fine…
    edit 2: think this problem is quite usual… would be helpful to put this info in the “installation-guide” I think – but not my job. Found this solution in the forum (seems to work fine, thx webtregy!):
    i solved in this way:
    before install template, in the zip package, in “templateDetails.xml” file
    i changed:
    <filename>highslide/highslide-with-html-bak.js</filename>
    with
    <filename>highslide/highslide-with-html.packed.js</filename>
    checkmate40 Friend
    #247834
    thanks man.
This topic contains 3 replies, has 2 voices, and was last updated by  checkmate40 16 years, 8 months ago.
