  • epiccentral Friend
    #128741
    I was doing a fresh install for JA Teline on Joomla 1.5.3. However during the installation process I received the following error message:
    <blockquote>
    * Unable to write entry
    Warning: file_put_contents() failed to open stream: Permission denied in /home/mysite/public_html/libraries/joomla/utilities/compat/php50x.php on line 66
    Warning: file_put_contents() failed to open stream: Permission denied in /home/mysite/public_html/libraries/joomla/utilities/compat/php50x.php on line 66</blockquote>
    I’ve changed the permission for all the directories to 777 but still getting the error. How to fix this?
    Thank you
    epiccentral Friend
    #249913
    Please ignore my previous message. The error is fixed.
    johnswallacejr Friend
    #262135
    Can you tell me how you fixed it?
    epiccentral Friend
    #262185
    I forgot to unzip the file first before installing! Unzipping will allow you to select the right file to install.
This topic contains 4 replies, has 2 voices, and was last updated by  epiccentral 16 years, 4 months ago.
