  • milestaylor Friend
    #130557
    I’ve just installed the latest version of ja_teline_ii_quickstart_v1.3_1.5.x on my webserver, having to unzip it on my PC, then FTPing it to the server.
    All the pre-requisite installation options were green, apart from the display errors one, which was red.
    After removing the installation folder I instantly got the following message:
    Fatal error: Class jplugin: Cannot inherit from undefined class jeventhandler in /home/jqsimkgl/public_html/profwriting/libraries/joomla/plugin/plugin.php on line 29
    I haven’t installed anything else. :confused:
    The URL is: http://www.visitgallery.com/profwriting/
    #258496
    Hi milestaylor !
    Please send me plugin.php file in libraries/joomla/plugin folder , i want look into it .
    Hainn, regards.
    milestaylor Friend
    #258631
    Hi Hainn,
    I’ve saved a copy of the plugin.php file as plugin.txt and attached it – seems I couldn’t upload a php file.
    Hope this helps. Thanks for looking into this for me.
    Miles
    1. plugin.txt
    #258685
    Hi milestaylor !
    there is problem in plugin.php file . you can fix it following way :
    – Download attachment file and extract it .
    – Copy and overwrite to libraries/joomla/plugin folder.
    Note : Don’t forget backup old file .
    milestaylor Friend
    #258850
    It works!
    Thanks Hainn – that’s fantastic! What was the problem?
    Miles
    cgc0202 Friend
    #258851
    <em>@hainn84 65186 wrote:</em><blockquote>Hi milestaylor !
    Note : Don’t forget backup old file .</blockquote>
    Can you please share what error was involved, Hain? And exactly what was done to fix it? Thanks. — Cornelio
    #258909
    Hi all !
    There is problem in plugin.php file .
    You open plugin text and plugin.php to compare at about line 29 :
    in plugin.txt file :
    class JPlugin extends JEventHandler
    in plugin.php file :
    problem at here is there isn’t JEventHandler in joomla .
    cgc0202 Friend
    #258929
    <em>@hainn84 65472 wrote:</em><blockquote>Hi all !
    problem at here is there isn’t JEventHandler in joomla .</blockquote>
    Hi hainn,
    Is this for both Joomla 1.0x and Joomla 1.5x?
    I understand from your explanation above that there is something missing? My actual question actually is this:
    How come some people here experienced the problem? I never did encounter this problem.
    As a follow up:
    What is not accomplished if there isn’t JEventHandler in joomla?
    Thanks,
    Cornelio
    #258939
    Hi cgc0202 !
    Maybe milestaylor have change or edit something on him site so , plugin.php file changed. I have check on teline ii package , plugin.php file is correct.
    cgc0202 Friend
    #258955
    <em>@hainn84 65506 wrote:</em><blockquote>Hi cgc0202 !
    Maybe milestaylor have change or edit something on him site so , plugin.php file changed. I have check on teline ii package , plugin.php file is correct.</blockquote>
    Thanks for the clarification Hainn,
    I do not want to be changing something, unless needed.
    Cornelio
This topic contains 10 replies, has 3 voices, and was last updated by  cgc0202 16 years, 6 months ago.
