  • photographycollection Friend
    #131443
    when I choose the zip-file JA Teline II v1.4 for Joomla 1.5x and click upload & install in the extension manager (Joomla 1.5.4) there is always the following error message: Error! Could not find an XML setup file in the package
    What can I do to solve the problem?
    Peter
    Menalto Friend
    #262723
    Unzip the file first, then you get 3 subfolders( template, quickstart and extensions), after you have done that you can find the zip file for the template and install it.
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 5 months ago.
